motor problems
Old Dec 9, 2008 | 08:33 AM
sk8erdude36's Avatar
Default motor problems
i have a 91 z28 camaro with a 305. the oter day i started it up and it stuttered and died, now it wont stay running. it will start and then die. what could be the problem and hhow can i fix it?
Old Dec 9, 2008 | 10:53 AM
Saint_Ali's Avatar
Default RE: motor problems
Check the battery, whats the voltage at ? Id also take the alternator out and get it tested at your local parts store.It could also be that the cat is clogged and is choking the engine and not letting it breathe
Old Dec 9, 2008 | 06:24 PM
i have a new alternator and its charging the battery. and i dont have a cat its a new edlebrock exhaust system. i was wondering if could be something clogged it the intake or fuel lines, etc. but i put fuel injector cleaner through it and it didnt help.
Old Dec 9, 2008 | 09:22 PM
c4maro's Avatar
Does it die when the choke turns off? And when you start it cold, does it idle as it would when it would idle warm?
Old Dec 13, 2008 | 07:28 PM
Tombomb's Avatar
have you tried the mass air flow? it will start and die within 5-10 seconds. but it won't start every time.
Or the crank sensor?
Old Jan 27, 2009 | 02:22 AM
anteeeze's Avatar
Default do some checks
U might wanna try to do some error code read outs to c what pops up also if tpi try to first disconnect the maf plug then see if it starts and runs and also with maf plugged in try to put car in service mode and start if its like a 89 this doesn't really mean ur maf is bad its just a start of diagnosing try not to buy parts just cus it seems like its it cause til u get to the root, it might be expensive...
Old Feb 4, 2009 | 06:49 PM
92ttopRS's Avatar
My 92 RS with 5.0 is just starting to do this. Very, very intermittent...maybe one time in 30 starts and it is driving me nuts. This motor has a fresh tune and runs very strong. 100% stock. All emissions in place. New EGR. I do all maintenance myself. Passed California smog on dyno a month ago with outstanding results. I cannot figure this one out. SES light is not on...does not come on. Any info would be hugely appreciated. I would love to stop this problem before it gets worse.
Graeme Cuthbert
Jul 24, 2014 08:50 AM
mp734
Nov 6, 2013 11:54 AM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
matt_s
Mar 16, 2007 10:49 PM
