carb problems or timing problems???
Old Jun 9, 2008 | 03:39 PM
IZZY1967RS's Avatar
Default carb problems or timing problems???
so i took my 67 out today. my car showed a quarter tank but it died. i thought i ran out of gas so i got it toabout 6 gallons. on my way back home, the rpms started gettin lower so i threw it into neutral and it stood on. as soon as i threw it into drive it died. i took apart the front part of the carb and the gas in there drained. i was able to turn it on and everytime i came down to a stop sign it was ready to die so i had to run the stop signs to keep it from dying. i made it to my driveway and it died. it has a hard time startin up. i just got the timing done about a month ago and it ran strong. over time though, i noticed the idle kept dropping. do you think its a timing problem, a carb problem, or somethin else??? can someone help me out? its my daily driver and i love that car sooo much!
Old Jun 9, 2008 | 06:00 PM
Default RE: carb problems or timing problems???
How old is your coil?
I've had that happen to me a couple of times with a bad coil. As the coil would heat up, and finally start to overheat, the engine would crap out.
Old Jun 9, 2008 | 08:30 PM
IZZY1967RS's Avatar
i had the coil changed last year in september. i hope thats the problem.
Old Jun 19, 2008 | 10:29 PM
frostlime69's Avatar
Fuel pump? Fuel filter? Start with basics and it might turn out to be something simple.
mp734
Nov 6, 2013 11:54 AM
manslaughter299
May 30, 2012 03:32 PM
Mass81Z28
Sep 20, 2007 08:38 PM
xc|bandit
Mar 30, 2006 08:16 AM
Dancj2
Jan 23, 2006 05:24 PM
