RS 350 engine swap help
Old Feb 3, 2009 | 12:48 PM
stinkyparp's Avatar
Default RS 350 engine swap help
Hi Guys,
i've got a 1991 305 tbi rs that i'm putting a 350 carb motor in and wanted a little advice!
The crate motor i've got my hands on has a mechanical pump fitted and i wondered what mods i would have to do to use it as i guess there's too many pipes running from the tank at present?
Also i would like to get some extra power from the 350 and was thinking heads(i have basic cast iron at present), but would you recommend standard gm vortec or edelbrock on a cost is an isuue as i'm fitting flowmaster, hedman etc and don't want to waste money, but also want to get good power!
Old Feb 3, 2009 | 01:22 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Get the car running smothly before you atart thinking about power adders. Fuel delivery is one of the most commoonissues overlooked and underestimated when doing a swap like this. You will need a fuel pressure regulator to calm the pressure down. I have capped of the return pipe before and I have also ran the return through the carb - either way it works.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
