oil leak
the motor is also leaking alot of oil but i can't find where its coming from. its not from the valve cover because i can run my finger along the edage all around it and nothing. I can see it puddling on the block in the back by the bell housing to the passenger side under the distributor. could it be leaking from around the distributor?
