Oil gauge needle pointing straight up
Old Jul 16, 2007 | 10:56 AM
citydragon's Avatar
Default Oil gauge needle pointing straight up
All of sudden my oil gauge needle has started pointing straight up as soon as I start up my car and stays up. Tried pulling the needle down with my finger, but it goes back up. I have a feeling that the gauge is gone. Anyone experience something like this...any tips?
1985 Camaro z28 4bbl, manual transmission. I've owned the car since new and have always kept everything working right on it. If it's the gauge, what would be your opinion of a used replacement tach/oil gauge from ebay.
Old Jul 16, 2007 | 02:50 PM
Default RE: Oil gauge needle pointing straight up
I don't remember whichdirections the oil gage turns on a 85. But what you are experiencing is not likely to be a gage problem, but most likely a bad sending unit, or a wiring problem between the gage and the sending unit. If the gage shows max pressure, theremay an open wire between the sending unit and the gage. Ifthe gage shows min pressure, the wire may be shorted to ground.
Old Jul 17, 2007 | 08:14 AM
ScottD's Avatar
Its a wiring issue.Mine does the same thing and Ive changed the cluster twice. Im running a mechanical guage now.
Old Jul 18, 2007 | 12:31 PM
citydragon's Avatar
Thanks for the replies...replaced the oil pressure sending sensor and all is working fine now.
mike6208
Sep 1, 2011 05:26 PM
z28?SS?
Apr 27, 2011 09:00 PM
southw2
Mar 4, 2011 07:13 PM
96ZLT1
Jan 10, 2011 09:50 AM
tipdrip215
Jan 10, 2009 09:59 PM
