Fuel Gauge Needle drop when driving
Old Aug 31, 2011 | 10:44 PM
mike6208's Avatar
Default Fuel Gauge Needle drop when driving
so i'm installing new guages in the dash, i have the fuel gauge all hooked up it works fine, drops to E when car is off and goes to fuel level when on. while driving, when i hit the gas the needle will drop to E then go back while driving. also it will drop when turning. where do i look first? fuel sender unit? or anything easier i can rule out first?
Old Sep 1, 2011 | 08:00 AM
Fill the tank with gas and then see if it still does it.
Old Sep 1, 2011 | 08:45 AM
BudBrown's Avatar
November 2011 ROTM
Ride of the Month Director
sounds like your tank is low on fuel... Is it? if not i would look for an electrical issue just to rule it out. it probably will be the sender unit, but ruling out an electrical issue is cheap, and in the long run can save you a ton of $. replacing the sender unit and then finding out it was an electrical issue, can be very costly.
Old Sep 1, 2011 | 10:03 AM
mike6208's Avatar
i have about a 1/4 tank left, ill have to fill it and check it out
Old Sep 1, 2011 | 05:26 PM
That's absolutely normal when you get down around 1/2 tank or less. Lower the level the more it changes when you corner or accelerate.
Turbolag86
Jan 13, 2010 09:09 AM
tipdrip215
Jan 10, 2009 09:59 PM
vzfox
Nov 10, 2007 10:05 PM
BlueKitsune
Oct 5, 2007 07:54 PM
citydragon
82-92 V8 Tech
Jul 18, 2007 12:31 PM
