Need Help URGENT!
Old Sep 3, 2011 | 11:11 PM
Berlinetta's Avatar
Exclamation Need Help URGENT!
Hi, I have a 1982 Berlinetta. Its an automatic 305.
It will not shift into park. I am leaving it in neutral with the e-brake up. Has anyone had a problem like this? Do i need a new tranny?
Thanks
Old Sep 3, 2011 | 11:18 PM
Is it not shifting into park, or park is not holding? If park is not holding there is a good chance that the parking pawl may have broken. Did you slam it into park while the car was still in motion, or was the car pushed around while in park? If it actually does not go in park, it may be a shift linkage problem.
Old Sep 4, 2011 | 02:01 AM
Berlinetta's Avatar
It was not slammed into park while in motion. I was at a complete stop and it wouldn't go into park. I muscled it into park and then the rpm jumped from 750 to 1500. It is extremely hard to shift into park and when i do the shift ***** button will stay depressed and be almost impossible to ring back into other gears.
Old Sep 4, 2011 | 08:49 AM
torque_is_good's Avatar
get underneath and find out if it will go into park using the lever on the tranny. It might just be a cable issue. But, you must begin the process of elimination
Old Sep 4, 2011 | 03:09 PM
Berlinetta's Avatar
alright i will do that.
Old Sep 5, 2011 | 04:17 PM
Berlinetta's Avatar
K I adjusted the lever from underneath, it went into park. Everything is fine now, except I have to push forward to release the lock on park. I dont mind that so its perfect now!
Thank you guys so much.
Old Sep 6, 2011 | 05:12 PM
hey hey hey
you're not done here.
You now need to pay for the information you received. You must make posts and help out someone else
Old Sep 6, 2011 | 07:34 PM
Berlinetta's Avatar
I will my friend, I do not understand what you mean by make posts though.
Old Sep 6, 2011 | 08:10 PM
gfrench's Avatar
He just means that you need to return the favor and help the next guy out.
You will not know all the answers, but sometime someone will ask something you do know. Help by responding to there post.
ColinGordon
May 3, 2012 02:16 PM
Dcapper81
Jan 8, 2012 11:11 PM
kuwait camaro
Sep 10, 2011 02:08 AM
iLL95
Aug 28, 2011 11:35 PM
alex941
Oct 4, 2010 09:59 PM
