Need help with heads
Old Apr 25, 2007 | 11:21 PM
89 Iroc Conv's Avatar
Default Need help with heads
My friend has offered me a 350 in which I thought that I would swap into my 89 vert I got the casting # off the heads and headed off to mortec.com to see what these heads where, but all the info that they offered was they came on 305&350 with 1.95-1.50 valves. I expected to get a little more info from them,so I am going toask for the knowledge of the forum to help me, the # of the heads are 14102193 if anyone has any info or opinions on these heads I would appr. it. They also said they were from 87up would they even work with my 89 tpi set up.[sm=badbadbad.gif]
Old Apr 26, 2007 | 11:32 AM
uradumass5695's Avatar
Default RE: Need help with heads
The heads are the same setup as long as both sets of headrs are years 87-95 and not vortec you have nothing to worry about. All you have to do is replace the throttle body and manifold with your TPI setup. You may have to re-map your computer though because of the different displacement.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
