heating
Old Jan 10, 2010 | 09:27 PM
blue87iroc350's Avatar
Default heating
so i have replaced my heater core and my heat worked fine when it started to get cold out as well as defrost. Then high went out and now medium has gone out. i have also replaced my thermostat. my defrost still works fine and my car warms up just fine and doesnt over heat. i just cant cant thing of anything. could it be a relay or anything?
Old Jan 11, 2010 | 07:49 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
so the blower speeds are going out?
Old Jan 11, 2010 | 01:34 PM
There is a resistor pack which is used to control the speed of the heater blower. The selector picks which resistors are needed to get the desired speed. You could have a defective switch, bad wiring, or burned out resistors. If the blower motor is worn, it becomes harder to spin and draws more power, which can cause the resistors to fail.
Old Jan 11, 2010 | 10:37 PM
well it also has a 2 year old blower motor as well. its just the speeds that are going out
Old Jan 12, 2010 | 07:38 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, blower motor resistor is bad. i wish i could tell you where it is, but i dont know its exact location
Old Jan 12, 2010 | 10:43 PM
yeah i was hoping it wasnt going to be that. i know where it is.
hb0180
Aug 28, 2011 02:02 PM
mrsdeano
Sep 23, 2010 10:35 AM
pkelly94z28
Jul 27, 2009 01:16 AM
GoofieJ21
Sep 24, 2007 07:32 PM
CAMAROcruiserFL
May 2, 2005 12:13 AM
