fuel pump troubleshooting
Old Nov 12, 2008 | 07:21 PM
blue max's Avatar
Default fuel pump troubleshooting
o.k. the fuel tank is out of my 89 iroc. now i have no voltage to the fuel pump connector. i beleive from looking at a wiring diagram, the gray wire should have 12 volts. none of the wires have any volts, not the gray or pink, i know the black is ground. how easy is it to convert to a out of tank fuel pump. where do i connect the wires. also i have an ignition problem. i want to install a push start button to start the engine. how do i connect that, is it to the starter solenoid.
thanks for your help.
94Zman
May 30, 2013 06:54 PM
jon_uscg2001
Aug 25, 2011 12:23 AM
Toymachine
Feb 23, 2010 01:52 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
