fuel pump ?
Old Nov 6, 2007 | 10:46 AM
littlebri's Avatar
Default fuel pump ?
Does anyone know the signs of a fuel pump on it's way out?
Old Nov 6, 2007 | 06:20 PM
Default RE: fuel pump ?
Yeah, your engine won't run! Are you experiencing any symptoms?
Old Nov 6, 2007 | 07:04 PM
littlebri's Avatar
When I start the car it runs fine for a little while, then while at idel the rpm's will drop down about 150-250 for about one second then they suddenly jump up to about 1000. It keeps doing this and if I sit long enough it sometimes stalls.
Thanks in advance
Old Nov 6, 2007 | 11:03 PM
Norris's Avatar
A fuel pressure test should give you a clue on the pump. I'd be checking out the idle air control valve and it's circuit on that one.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
