engine swap
Old Aug 31, 2008 | 03:42 PM
snapper08's Avatar
Default engine swap
I want to swap out my cross fire injection for a carb 350, what all am i gonna have to change? Does the speedo run off the computer or was it still mechanical with this FI? Any other information would be greatly appreciated
Old Aug 31, 2008 | 05:50 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default RE: engine swap
You wont have to change much. Get rid of the 305 stuff (engine, computer, wiring harness (from the pass. side, not the drivers side wiring harness.) The speedo is cable driven, so no problems there. Your biggest problem will be the fuel system. You will have to use a regulator if you want to retain the stock electric pump, if not you will have to remove the pump and either install an inline electric pump or a mechanical pump. Other than that its pretty much straight forward.
Old Sep 3, 2008 | 07:55 PM
snapper08's Avatar
Is the fuel pump the only problem i will run into?
Old Sep 3, 2008 | 08:09 PM
August 2009 ROTM
Basically, yes. The previous owner of my car put a carb on the orginal motor, the only thing they had to change was the fuel pump, and they also removed all the computer BS. Recently I swapped a 350 in, didnt have to change a thing except what I chose. I would however use a flex fan or a good electric fan along with a new radiator, I had the clutch fan on mine and it was overheating, put a flex fan on and its all good.
Old Sep 3, 2008 | 08:41 PM
snapper08's Avatar
so if i want to put a mechanical fuel pump on the side of the motor do i have to drop the tank and take the electric one out or can you just unplug it somehow? You were great help thanks
Old Sep 4, 2008 | 08:30 PM
August 2009 ROTM
You will either have to drop the tank (major PITA), or cut a whole above the tank under the carpet. I would put a new mechanical pickup in, then you will not have to worry about it.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
