89 need help bad! multi questions!
Old Mar 18, 2009 | 08:18 PM
FYI, Every time you try an incorrect resistor you will have to wait. I think its like 5 minutes before the system will reset and allow the correct resistor work right.
Old Mar 24, 2009 | 06:47 PM
microkid's Avatar
March 2011 ROTM
Technical User
save yourself hacking into the wires and ruining your pcm. its going to be about $200 to have a locksmith come and make a key after you get the serial data from a dealer through the vin. the serial data will give them the value for the correct resistor key. i was just going through this over the weekend because i lost the keys to my blazer, but later found them in my sweat shirt
Old Apr 2, 2009 | 08:11 AM
blue max's Avatar
z28pete, i have the same problem he has. i have a # 12 key, 6000 ohm resister. could you please explain in detail how to wire it in. what color wires are involved. a schematic would be helpful. also can you explain the relearn key procedure. thanks for your help.
maroman26
Aug 9, 2011 12:20 PM
chevymansmp790
82-92 V8 Tech
Feb 12, 2008 07:51 PM
Rs Camaro Kid
Jan 7, 2007 11:52 PM
todd991
Apr 23, 2006 03:13 PM
