88 Camaro with stock 350
Old May 25, 2010 | 09:10 AM
Winston Norris's Avatar
Default 88 Camaro with stock 350
I have an 88 camaro with what i believe to be a stock 350 and a 700r4 tranny. Im not entirely sure what the best build is for my car. I am thinking about boring it .30 over and build it up from there. If you have any advice for me i would appreciate the it.
Old May 25, 2010 | 12:10 PM
djs383's Avatar
What exactly do you want to do with it?
Old May 25, 2010 | 01:15 PM
im gonna try to get it to push around 13 seconds and 400 hp. I plan on doing an entire engine rebuild but im not sure exactly what i should get to make it run faster. Im going to bump up the compression and most likely get new cams.
Old May 25, 2010 | 01:19 PM
blackz87's Avatar
High 13's is possible and 400 HP might be a reach.
Old May 25, 2010 | 01:21 PM
im more worried about the time then i am the hp. I just want it to be running rough 13's for now. I plan on dropping a 454 in it in the future but not any time soon.
Old May 25, 2010 | 02:34 PM
blackz87's Avatar
IF you don't spin the tires and with some decent mods you should break in the high 13's @ about 97/98mph.
Old May 25, 2010 | 02:58 PM
well i plan on investing some money into it but im not sure what cams i should get or other modifications that would make a big difference
Old May 26, 2010 | 07:38 AM
blackz87's Avatar
Just a suggestion: Take your car to the Track and establish a baseline run before any new mods are added. After you can make a new run and check if the money and work are worth it.
Old May 26, 2010 | 08:15 AM
well my tranny is slipping so i figure im gonna take that apart and rebuild it so i might as well fix up the engine as well
hevymetalg
May 21, 2009 11:53 PM
bigrip1154
General Racing/Tech
17
Nov 2, 2007 11:54 PM
96Camaro3800II
VS
Aug 17, 2006 01:21 PM
toysarefun
May 14, 2006 10:40 PM
