86 camaro
Old Apr 6, 2026 | 09:04 PM
drob1259's Avatar
Default 86 camaro
Picked up an 86 camaro today, car originally came with a v6 that now has a 89 350 tpi motor in it. From what the previous owner told me car is not receiving injector fire command from ecu. If you spray starting fluid in throttle body motor fires and runs as long as you keep it primed with fluid, asked if they put a v8 ecu and harness in and he said yes.Can this be as simple as a vats problem, vats and ecu not recognizing key because it's not original ecu. Your thoughts will be appreciated.
Old Apr 9, 2026 | 07:39 AM
have you hooked up a scanner? flash for codes?
Old Apr 9, 2026 | 08:12 AM
drob1259's Avatar
Thanks for the info, even though the car itself did not come with vats, the ecu they used has it so going to flash it and delete vats from it
Old Apr 10, 2026 | 05:17 PM
Tealcamaro
Feb 5, 2019 08:14 AM
boboridesthefa
Jul 26, 2014 02:50 PM
gbettner
82-92 V8 Tech
13
May 3, 2013 12:03 PM
smbigfoot
Aug 14, 2012 07:36 AM
smbigfoot
Jul 9, 2012 08:57 AM
