1991 Camaro Dies In Gear
Old Nov 23, 2013 | 09:59 AM
TipTricky's Avatar
Default 1991 Camaro Dies In Gear
I just got the car and it has problems i know but it was 500 dollars for a L98 Camaro i couldnt help my self haha. When you put the car in gear it bogs a little then dies. I hear this can happen if the idle air control valve is dirty/bad and im going to clean it up and change the plug on it Wednesday but is there anything else i should do while im at it?
Parts list for now:
Ignition Module
Sparky Plugs
Cap and Rotter
Throttle Position Sensor
TV Cable
Intake Gaskets
Alternator
Air Filters
Is there anything else i should think about changing? Spark plug wires are new already as is the battery so those are covered.
Old Nov 23, 2013 | 11:53 AM
RonnieJ86's Avatar
You could add a water pump to the list and flushing the radiator system to make sure its all clean and good to go. Thats what I did with my 91 and I bought it cheap too at $700
Old Nov 23, 2013 | 07:23 PM
TipTricky's Avatar
I flushed the radiator already and changed fluids swaping the tranny out this week as well. Probably should change the water pump, temp sensor, and thermostat as well.
Old Jan 5, 2014 | 02:21 PM
TipTricky's Avatar
So i changed everything on my list plus IAC but the car still bogs and dies in gear but if you give it a little gas when you first put it in gear it will stay running when you let off the gas. It has a bad TPS could that cause this?
Old Jan 5, 2014 | 02:50 PM
RonnieJ86's Avatar
yeah it could be I had a issue with that with a integra, changed the tps and it fixed it so it maybe be the fix for yours too.
Old Jul 5, 2014 | 10:27 AM
Weldinchevys's Avatar
I had a buddy that had this same problem, he kept telling me it was his tourque converter. That it didn't want to turn when it was in gear but if you put some power behind it she would stay alive. I'm not sure if this is even a culprit but I've hear it through the grape vine. Unless it's a manual car then it's over my head. Good luck!!!
Old Jul 5, 2014 | 11:53 AM
blackz87's Avatar
TPS should not be a problem. Sounds like you are not getting any gas. What does the car idle at??? I would forget everything else until you get it running right. Is it a TBI or TPI car.
Old Jul 5, 2014 | 08:04 PM
greenmachine96's Avatar
check fuel pressure i bet you have a fuel filter thats stopped up. Or maybe a vacuum leak too.
grapeape1
Jun 28, 2014 03:12 PM
Armored Camaro 91
Jun 23, 2013 10:23 AM
Joey Valentine
Aug 27, 2011 02:36 PM
gearhead79rs
70-81 V8 Tech
Apr 28, 2011 05:47 PM
neversave
82-92 V6 Tech
Jan 19, 2009 09:59 PM
