1986 I-Rocc wont start help please
Old Jan 11, 2010 | 12:27 PM
SupremeC84's Avatar
Default 1986 I-Rocc wont start help please
I put new starter,battery,distributor cap and car wont turn over. When I turn the key the volt meter on the dash drops and interior lights dim. I beleive its getting gas but Im thinking something is not sparking right dont know if you can help would appreciate.
Old Jan 11, 2010 | 02:39 PM
"Won't turn over" means the engine doesn't crank, move, or budge when you turn the key. Is that what you meant? Could be anything from bad battery connections, a ground issue, or the engine is locked up. If it isn't turning over, try it by hand to make sure nothing is seized. What kind of symptoms, if any, were you getting before you started replacing parts?
Old Jan 18, 2010 | 08:38 PM
Ron Messenger's Avatar
From: I live in northern Illinois in the Rockford area.
on my 86 i had the same problem and didnt know what the problem was after talking with a gm tech he told me that if the battery ends were not tight enough the spark from the battery would not jump to the cable so make sure they are tight
polinder_88
82-92 V8 Tech
Apr 10, 2014 11:33 PM
wantvegas
Aug 1, 2013 12:50 PM
karma187357
Oct 19, 2011 08:08 AM
kamaro68
Mar 14, 2008 09:27 PM
kamaro68
Mar 12, 2008 02:25 PM
