Carb problem on '83 Camaro
Old Nov 19, 2011 | 01:15 PM
Libert's Avatar
I've been working on the carb some more. The gas filter is fine. The choke is operating well. All vacuum lines have been triple checked and seem fine. I've tried the carb float in 3 spots in a range from 8/32-13/32" (I found these measurements in more than one spot).
The car idles fine when cold. But if I hit the accelerator hard, I get definite hesitation. As the car warms, it stalls unless I keep it idling at about 1300 rpm (normal should be around 800).
In a diagnostic manual, it suggested testing the EGR valve with the engine warm. The test was partly whether it changed idle speed or not. It didn't, but again, I've got it idling high to keep from stalling. Besides, the car worked pretty well before the rebuild, so it sure seems like it's something I've done (or didn't do).
As I moved the float up and down, the needle did not move at all that I could see. I'm on my second rebuild kit, so switched out the needle with the other new one. The spring from which it hangs was shaped slightly differently, and with this one, I get some visible movement, although quite small.
Any thoughts? And thanks!
fishbone
82-92 V8 Tech
Oct 20, 2010 03:51 PM
TG_69
Aug 11, 2010 05:00 AM
2lucke4u
Sep 1, 2006 09:55 PM
bowtieguy
Mar 3, 2006 08:00 PM
srober76
Nov 15, 2005 02:35 PM
