1987 camaro 2.8 5speed please help..
bought the car about 3 weeks ago had to replace fuel pump, replaced filter, and a few other things, after that she started up and purred, went to start it up agian a few days ago and wont start, fuel pump wont even humm, is it possible to get 2 bad fuel pumps or could it be something else? Trying to avoid dropping the fuel tank for a third time. Can anyone help? thank you
It is highly possible to get multiple bad fuel pumps. The companies by parts in bulk and continue using the parts until they are made away of there defects.
Something in the gas tank yes if the fuel strainer is clogged it can cut of you fuel supply and fry the pump.
