Tranny ??
Old Oct 4, 2011 | 10:38 AM
carlallen's Avatar
Default Tranny ??
Lets see if i can explain this right, i have a 86 iroc z that was tpi with 700r4 well i turned it into carb with a older 350 motor bored 30 over and has a bigger cam in it, so now the question I had to put a stall convertor with my 700r4 and the 700r4 is rebuilt, but still it does what seems like a long shift and when it finally does shift it feels jerky. We unhooked the computer and it seemed to help but started it again?? thanks
Old Oct 4, 2011 | 11:11 AM
The only transmission part affected by the computer is the TTC, and that does not affect shift quality. Is the TV cable adjusted properly?
Old Oct 6, 2011 | 02:03 PM
carlallen's Avatar
Alright, so could only two problems be that the cable is off or transmission got rebuilt badly?
Can you give me and info on how the cable should be set? I knwo its hooked and and seems right liek when you move throttle the cable extendes all way out then back in.
Old Oct 7, 2011 | 11:32 AM
carlallen's Avatar
Also I have aftermarket shifter in it and where shifter goes there was another cable besides shifter cable, im not sure what its for but its not hooked up.
WIspartan1026
Mar 25, 2010 09:58 PM
bhoeksema
Mar 6, 2010 08:38 PM
blowncamaro
Oct 12, 2009 09:05 PM
rancheronut
Jul 14, 2009 01:12 AM
mpd228
May 11, 2009 09:52 PM
