Rear end swap?
Old Nov 27, 2011 | 07:32 PM
FowlerMotorsports's Avatar
Default Rear end swap?
How wide is the 7.5 GM rear end in the 3rd gen camaros? I know it is wider than the 8.5 from the earlier generation which is 58", but how big of a difference is it?
Old Nov 27, 2011 | 09:14 PM
77 kencraft's Avatar
stronger rearend for 82-92 camaro see if this will help out on hot rodders forum
Old Nov 27, 2011 | 09:35 PM
Thanks! I appreciate it
Old Nov 27, 2011 | 10:00 PM
This gives the mounting flange to flange dimensions, not wheel hub to hub dimensions. If that helps at all.
MalibuRacing.com - FAQ's
Old Nov 27, 2011 | 10:40 PM
iLL95's Avatar
I Like to Party
Super Member
What rear end are you planning to swap?
20camaro02
Jan 19, 2013 10:42 PM
draggo144
Mar 31, 2010 09:14 AM
dejz28
Mar 13, 2009 12:58 PM
mike83camaroBA
82-92 V8 Tech
Oct 30, 2008 12:00 AM
68ssap
Oct 8, 2007 11:04 PM
