Rear end swap?
How wide is the 7.5 GM rear end in the 3rd gen camaros? I know it is wider than the 8.5 from the earlier generation which is 58", but how big of a difference is it?
stronger rearend for 82-92 camaro see if this will help out on hot rodders forum
Thanks! I appreciate it
This gives the mounting flange to flange dimensions, not wheel hub to hub dimensions. If that helps at all.
MalibuRacing.com - FAQ's |
What rear end are you planning to swap?
