rear end swap
Old Oct 28, 2008 | 05:45 PM
mike83camaroBA's Avatar
Default rear end swap
i probably know the answer to this question but i just thought i would ask it anyways. would a rear end out of a 4th gen bolt up into a 3rd gen?
Old Oct 28, 2008 | 06:11 PM
MadMikeZ28's Avatar
Default RE: rear end swap
Well if you know the answer, what do you think? And no cheatting and searching for any threads with this question already answered.
Old Oct 28, 2008 | 06:37 PM
Lithorian's Avatar
yes, just make sure you have the right proportioning (combination) valve for which ever brakes the 4th gen diff has.
Old Oct 28, 2008 | 10:40 PM
im pretty sure it will, my brother has a 4th gen and they look just about identical, i want to keep the posi and add rear disc.
Old Oct 28, 2008 | 10:54 PM
MadMikeZ28's Avatar
It is a few inches wider. Might be fine with a different offset wheel. Or mud flaps. And as mentioned don't forget to replace the proportion valve for a drum to disc swap. If its an 83 you are working on you will have to find a valve with the line configuration of the 83. My valve on my 84 with disc was differentfrom my 91
Old Oct 29, 2008 | 12:13 PM
ok its wider but the mounting points will match up? its not an 83 its a 91 my 83 got rearended. where is the proportioning valve? wider might actually look good though.
Old Oct 29, 2008 | 02:06 PM
Lithorian's Avatar
proportioning valve is mounted directly under the master cylinder, but yes the 4th gen diff will fit easily with little to no modification
Old Oct 29, 2008 | 04:41 PM
MadMikeZ28's Avatar
ORIGINAL: mike83camaroBA
Its only like 2" wider on each side.
And regardless of what year your car is, if you go to the wrecker to get a valve just don't jump into the first F body you see with disc and grab it. You might find out you have too many brake lines and they don't line up in the respective holes.
Old Oct 29, 2008 | 10:16 PM
you are talking about brake lines into the valve correct?
Old Oct 30, 2008 | 12:00 AM
MadMikeZ28's Avatar
Yes. Not all the valves have the same line configuration. But you can easily get a valve for your 91. I looked and could not find my invoice for the part number from when I got the valve for my 91. But new jobber cost I think was around $50 +/-
20camaro02
Jan 19, 2013 10:42 PM
FowlerMotorsports
Nov 27, 2011 10:40 PM
draggo144
Mar 31, 2010 09:14 AM
dejz28
Mar 13, 2009 12:58 PM
68ssap
Oct 8, 2007 11:04 PM
