Best possible gear
Lemme guess....you didn't change the gear in the trans to recalibrate the speedo? If you didn't, you'll still be (think you are) "going" 70 mph at 4k rpm's even if you had 2.56 gears.
^ I thought that for a moment too. But he has an 82 with a 383 and T10 trans, which would also mean cable driven speedo.
There's absolutely no way your speed to rpm ratio would be the same after a gear swap.
Tell your tire height, and I'll let you know what it should be doing.
