Best possible gear
Old Nov 24, 2010 | 03:55 PM
LetsRocZ28's Avatar
So we swapped the rear end to 3:45s and we are still hitting 70 mph around 4k rpm do you think 3:08s will work for power and top speed
Old Nov 24, 2010 | 05:07 PM
Lemme guess....you didn't change the gear in the trans to recalibrate the speedo? If you didn't, you'll still be (think you are) "going" 70 mph at 4k rpm's even if you had 2.56 gears.
Old Nov 24, 2010 | 05:48 PM
LetsRocZ28's Avatar
No speedo broken side by side with another car as well as gps
Old Nov 24, 2010 | 08:14 PM
then thats most likely the problem. get the speedo fixed. if the trans does not know how fast your going it does not want to shift. to it your going 0.
Old Nov 24, 2010 | 09:47 PM
^ I thought that for a moment too. But he has an 82 with a 383 and T10 trans, which would also mean cable driven speedo.
There's absolutely no way your speed to rpm ratio would be the same after a gear swap.
Tell your tire height, and I'll let you know what it should be doing.
Old Nov 24, 2010 | 11:14 PM
dang in the wrong thread. id delete it but then you would look silly, please excuse my hasty post. lol. happy holiday.
Old Jan 10, 2011 | 07:23 PM
hotrod32's Avatar
Our 82 trans am has 3.23 gears, and runs right around 3k @ 70mph. Turbo 350, 14" 225 70 14's.
JordanN
Jun 2, 2012 09:40 PM
3.4putter
Jan 28, 2012 07:35 PM
numskull223
Jan 17, 2012 04:29 PM
SS_2000
LS Series Tech
May 24, 2010 07:50 AM
VTownSuzieQ
Nov 24, 2006 09:28 PM
