Question on the rear swaybar.
Old Aug 10, 2007 | 11:59 PM
burnout's Avatar
Default Question on the rear swaybar.
Well I have a 1985 V6 camaro, which means it didnt come with the rear swaybar, but you can bolt one right up to it easy, my only question is, is there anyonw out there than can send me a pic or post it of their rear sway, the last time I had it in, it dented my differential cap so badly that the gears ground through and made a hole. (needless to say that rear end is trash). I'm just wondering how exactly it should look up to the differential. Hopefully this time I can get it right! Before i do another $300 mistake.
Old Aug 14, 2007 | 10:05 AM
CamaroKid16's Avatar
Default RE: Question on the rear swaybar.
it should have two end links, one on each side right in front of the shocks, and then it bolts around your axle so it wont go denting ****. You need to buy an adapter kit or something like that since it didnt come with one.
Old Aug 14, 2007 | 11:59 AM
Skyrunner's Avatar
Didn;t the 3rd. gen have the F41 option package that included a rear swaybar?
Old Aug 14, 2007 | 02:35 PM
Skyrunner's Avatar
I believe the F41 suspension option did include a rear sway bar. If you have the F$! you should have a sway bar. Check your option packages to see what came with the car. You can have your dealer run the VIN and get a printout of every option on that car.It's a service GM offers and they don;t charge for it. The parts dept. should be able to do that for you. Takes about 60 seconds.
Old Aug 15, 2007 | 12:55 AM
1969 SS's Avatar
ORIGINAL: burnout
ouch, now that is a tuff learning curve to go through. I guess we all started somewhere though
Old Aug 15, 2007 | 08:48 AM
Skyrunner's Avatar
Well help me learn it then
Old Aug 15, 2007 | 08:49 AM
Skyrunner's Avatar
I though it was a fair question. So what's this forum for?
Old Aug 15, 2007 | 12:29 PM
Skyrunner's Avatar
OK, where is everyone. I want to know about the F41 suspension and swaybars.
Old Aug 17, 2007 | 12:55 AM
i know all about 4th gen suspension... i told ya i believe you need an adapter kit for it if it didn't come with one, but, that's all i got.
JPrice
May 20, 2012 03:48 PM
RatCamaro
Feb 6, 2011 07:05 PM
kudnu89
Jan 11, 2011 08:29 AM
bowtieguy
Mar 3, 2010 08:10 PM
91camaropalmer
Dec 20, 2009 04:19 PM
