Need some help with my brakes 1992
Old Oct 30, 2006 | 11:55 PM
Goodfella's Avatar
Default Need some help with my brakes 1992
okay so a while back i replaced my rear shoes, and a couple weeks later i noticed that they were extremely grabby and i would hardly tap the pedal and the back would lock up. also sometimes the pedal would drop. i immedieately suspected i had a leak somewhere... so i remember back while i was doing this i think i damaged the wheel cylinder... so i took it in and sure enough i did in fact damage it. so it costed almost $300 to fix this and to top it all off, i had installed them BACKWARDS!!!! dammit im retarded. so the first day back on the road is fine... the second day fine. the third day is when i first notice that they were beginning to grab. today it takes a while in the pedal's range of motion to actually get to the braking part and when it does get there i locked them up. what the hell is happening? suggestions? what should I check out? or should i just take it back?
thanks for reading about my misfortune.
Old Nov 22, 2006 | 11:12 AM
mattvogt's Avatar
Default RE: Need some help with my brakes
I am assuming that you took it to a shop for the wheel cylinder. It shouldnt have cost you 300 but I would take it back if your still having problems. Good luck
Old Nov 22, 2006 | 12:57 PM
shnormo's Avatar
Did you reverse it to a considerable speed then hit the brakes to set the self adjuster?
Old Nov 22, 2006 | 02:44 PM
Set the adjustment as Norm described, do it several times, if still bad go back to the shop, they charged you enough that the work should have a warranty. Don't try fixing it yourself, as then you will get blamed for causing the trouble and be stuck with the repair bill.
camarodude77
Dec 16, 2015 05:52 PM
Steven_Jarhead
Mar 10, 2012 12:02 AM
osduck5
Jun 12, 2009 08:47 PM
joshuaarch
82-92 V6 Tech
Nov 11, 2007 06:53 PM
TheJock60
82-92 V6 Tech
Oct 31, 2007 08:51 PM
