Engine swap
Old Nov 2, 2012 | 09:33 PM
Smboyte's Avatar
Default Engine swap
I just got a 88 camero with a 70's model
350 , theres no room for a breather, i really dont want to put on a scooped hood , any suggestions
Old Nov 2, 2012 | 09:39 PM
MKCoconuts's Avatar
What's a CamEro you speak of?
And are you talking about a oil breather?
Old Nov 2, 2012 | 09:51 PM
Smboyte's Avatar
Haha Camaro
The carb is to close to the hood
Air breather is hitting
Old Nov 2, 2012 | 10:06 PM
MKCoconuts's Avatar
How can it be too close? There's a lot of room to work with under there!
Old Nov 3, 2012 | 12:05 AM
Hood clearance problems.....what's that?
Might be you have a high rise intake manifold. What kind do you have? And have you tried a dropped base air cleaner?
Old Nov 5, 2012 | 12:27 AM
macertheracer's Avatar
body lift
sorry I just had to do it!!!!
Old Nov 5, 2012 | 12:30 AM
seriously look for something like the vortec 5.7 uses only big enough to fit on your carb, then use a cone filter with a CAI setup!
Old Nov 5, 2012 | 09:18 AM
djs383's Avatar
Most of the time, unless its a very high rise manifold it should fit. Verify by removing the carb air cleaner stud and measuring your available hood clearance. I had similar issues on a 3rd gen. After a drop base cleaner that cleared the choke...I was fine.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
