why does my car suck?!?!?!
Old May 9, 2008 | 10:06 PM
irocktheIROC's Avatar
Default RE: why does my car suck?!?!?!
i want a 5spd...trade me for my iroc z!
Old May 9, 2008 | 10:18 PM
karlisdad2005's Avatar
ORIGINAL: 84VarinZ28
alright here's step by step what you should do...
1) open door
2) pull hood latch
3) open hood
4) check clutch fluid reservoir (if low proceed to step 5) (if full proceed to step 8)
5) put brake fluid in the clutch fluid reservoir (The clutch uses brake fluid) (it's science)
6) pump the clutch pedal, after 1-174 pumps, look under the car for the fluid leak
7) repair/replace the leaking component
8) fill gas tank to 3/4 full
9) get a running start and slide across the hood
10) start the car, man up, and drift corners all day (if this doesn't work proceed to 11)
11) look for mechanical breakage ordisintigrated throw out-bearing
12) if all else fails replace motor!!!
Thats the best advice i have ever seen anyone offer! lol i love it!
Old May 10, 2008 | 08:19 AM
rockin85's Avatar
ORIGINAL: irocktheIROC
are you serious? i wiould do that in a heart beat. your car is prolly better than mine in every way. 350 horse and 411 tq...... id be lucky to get 260 hp out of this WITH a cam. but im gonna be building a 383 soon, im shooting for 500 horses n/a. then i might slap on a s/c if i have the cash.
Old May 10, 2008 | 12:21 PM
Gordon24Camaro's Avatar
Master Cylinder
this part failed on my 89.
when i tried starting the car it would move right away. i had to double clutch for a week before i got it fixed. Red lights SUCKED. Good luck, just so you know, the master cyclinder is attached to the actual clutch pedal, its the force that gives you the freedom tomanipulate the clutch.
Old May 10, 2008 | 08:42 PM
rockin85, where you at? lets make a dealeooo
Old May 11, 2008 | 01:40 AM
caldwell91camaro's Avatar
good luck man with the car but it all pays off in the end having a nice ride for them days off
maggie67rs
May 18, 2011 06:25 AM
2fast4u
General Racing/Tech
Mar 26, 2008 03:40 PM
