Where to hook vac lines on new Holley?
Old Jan 25, 2010 | 05:31 PM
ScottD's Avatar
Default Where to hook vac lines on new Holley?
The new 670 Avenger has 3 vacuum ports. There is one up front, next to the sight plug, and two on the bottom front below the fuel bowl. I assume that.......
The one next to the sight plug is for vac advance
The small one below the float bowl get run back down to the transmission
The third, larger, below the bowl is obviously PCV.
Do I have it right?
Secondly, there is no provision for the brake booster, again I assume I just go right into the intake manifold for that?
(I bought it refurbed, no instruction manual!)
Old Jan 25, 2010 | 05:34 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Do I have it right?
Sounds like you got it right (at least that's how mine was.)
You always want to go off the manifold for power brakes, so you need a fitting to go from the port on the intake to the brake booster.
Old Jan 25, 2010 | 05:47 PM
Now you have a manual: http://www.holley.com/data/Products/...99R10219-3.pdf
Read page 6
Old Jan 25, 2010 | 06:25 PM
August 2009 ROTM
I disagree with where they say to tap for power brakes. I was always taught to go off manifold vacuum and not port vacuum.
Old Jan 25, 2010 | 06:32 PM
That tap is in the base plate, manifold vacuum.
Old Jan 25, 2010 | 06:41 PM
August 2009 ROTM
Yeah, looking again you are correct. However I was still taught tap directly from the manifold as gunk and carbon deposits can build up around the ports on the base plate, reducing the efficiency of the power brakes.
isaackrammes
Nov 26, 2014 06:26 AM
jeffchairs
Sep 7, 2014 02:25 PM
250motorsportz
Mar 31, 2008 12:57 AM
blkgagt94
Feb 21, 2008 05:41 PM
microkid
Jun 4, 2007 08:20 PM
