What temperature should a 91 Camaro Rs run?
Old Mar 18, 2007 | 02:43 PM
91CamRS's Avatar
Default What temperature should a 91 Camaro Rs run?
Okay, I own a 91 Camaro RS and ive had it for about 2 weeks, it runs good but i've noticed it runs about 220 temperature wise.To cool it downI put the heater on and roll down the windows to bring it down to about 180-190, and I would like to know if 220 is normal or ifI should have anything checked?
Old Mar 18, 2007 | 06:30 PM
coprunr's Avatar
Default RE: What temperature should a 91 Camaro Rs run?
most i have seen run 210 with a stock t-stat. so yeah you are alittle on the high side , but that could be a temp sending unit or gauge inaccuracy. check the condition and level of your coolant, you may a touch low on coolant or it may new the cooling system flush and filled with the proper coolant mixture.
Old Mar 18, 2007 | 08:52 PM
microkid's Avatar
March 2011 ROTM
Technical User
no matter the t-stat temp, the fans dont turn on until around 225. this was designed by gm as a hotter engine burns cleaner, and gm was obsessed about emissions with these cars. you can buy an adjustable temp switch, or just put one on there yourself for easy on/off
Old Mar 18, 2007 | 08:59 PM
Abyliks's Avatar
stock fan turn on is 238*, the cars do run hot, im getting a 170* tstat and a lower fan switch
Old Mar 18, 2007 | 10:06 PM
92camaroRS's Avatar
Abyliks, did you buy the auburnposi differentialwith the 3.73s already in it?
Old Mar 18, 2007 | 10:37 PM
FlufyTiger's Avatar
The stock thermostat won't open completely untill about 220, but under normal conditions in a moderate, or cold climate, they don't have to open completely. Chances are that you just need to flush and refill the cooling system. If the problem still persists, check the operation of your coolant tempriture sending unit, and replace it if needed. You might also want to go ahead and test that thermostat to see if it's opening when it should.
Old Mar 19, 2007 | 06:54 PM
Abyliks's Avatar
yes, however i need to pull a cover, the guy had two of em and now he thinks i have the wonderful granade-lok[8D]i cant belieive i forgot that when i got it
pcarollo
Aug 30, 2014 08:58 AM
hugo_sm
Jan 27, 2014 01:43 PM
1996z28camaro
Apr 15, 2013 10:11 AM
lalokera956
Feb 16, 2011 02:50 PM
nazariol
Nov 24, 2009 07:07 AM
