Rear End
Old Mar 18, 2007 | 02:05 PM
smby101's Avatar
Default Rear End
On my 86 iroc-z tpi 305 how can i tell if the rear end is positive traction or not
Old Mar 18, 2007 | 02:32 PM
blackz87's Avatar
Default RE: Rear End
Check your RPO codes located on the underside of your center console lid. RPO G80 is the code for a Limited Slip rear (not positive traction).
Old Mar 18, 2007 | 03:39 PM
MadMikeZ28's Avatar
Jack up the car and if there is no tag on the diff cover saying it is spin a wheel. The other wheel will spin in the same direction.
Positraction is GM's brand name for limited slip.
Old Mar 18, 2007 | 04:17 PM
92camaroRS's Avatar
I cant find the RPO codes, where again are these located? The're noton my center console lid.
Old Mar 19, 2007 | 12:24 AM
92camaroRS's Avatar
So if i jack it up and i spin one wheel and the other spins the same direction then i have posi?
Old Mar 19, 2007 | 09:43 AM
blackz87's Avatar
The only sure way is to take the cover off and look. You will have a carrier that looks like the picture. If not , you DO not have a Limited Slip rear (note correct term "not Posi").
[IMG]local://upfiles/2696/9836C002788F43138D499449413647B5.jpg[/IMG]
Old Mar 19, 2007 | 06:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
easiest way to tell is jack up both rear wheels and try to spin them (with the brake off). it should be a posi. also, the codes wont be on the lide, but on the passenger side of the console (thats where mine is)
Old Mar 19, 2007 | 07:00 PM
MadMikeZ28's Avatar
No need to take the cover off. If its a LSD it will do its job and spin both wheels in the same direction.
Old Mar 19, 2007 | 09:42 PM
92camaroRS's Avatar
What passenger side of the console? Im not seeing it.
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
