vibration/shimmy?
Old Oct 13, 2005 | 03:36 PM
85Camarodude's Avatar
Default vibration/shimmy?
2.8l v6.....when i press my brake at approx. 35-40 mph my car feels like its tryin to shake water off like a dog
it doesnt happen at just 35-40 mph, sometimes a little lower but mostly around that time
tire balancing? drive shaft? brakes?
any help is appreciated
Old Oct 13, 2005 | 04:32 PM
Metsubo's Avatar
Default RE: vibration/shimmy?
With my very limited knowledge of cars, I can say that it might just be that your brakes might have been tightened too much. My Cavalier does that when I going fairly slow and then hit the brakes, the ABS will go nut.
Old Oct 13, 2005 | 06:35 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
warped rotor possibly
Old Oct 17, 2005 | 10:09 PM
i was thinkin warped rotor as well, i took it to the place i bought the wheels from thinkin i might be able to con them into fixing it for free sayin they over torqued my lugs but that didnt work lol so i took it to a shop close to my house. the rotors werent warped hardly at all but i had em turn them neways. well the car didnt shimmy when i pressed the brake nemore but i got goin down the road little ways to about 45 mph and it started shakin hardcore without me pressin the brakes so i took it back. they said i had a bad tire in the front so we switched the suspected one to the rear and the rear started floppin around. the mechanic then told me i just had a bad tire. welp by this time i was pissed b/c the wheel guys told me they couldnt help. so i go back to the wheel place and demanded them fix or replace their screw up. so they took it off and put it on the balancer and it was off 1/2 ounce. they fixed it for free. the end.....yay
Old Oct 18, 2005 | 12:02 AM
Good for you, now you have a nice smooth running car.
Old Oct 20, 2005 | 07:14 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
good thing it was somethin easy
claude1991
Mar 27, 2011 10:39 PM
glockman
North East
Oct 16, 2010 04:49 PM
purpl96
Oct 27, 2008 10:39 AM
1stgenssclone
Jan 2, 2008 11:24 PM
85Camarodude
Nov 17, 2005 08:28 PM
