V8 swap....Which engines will work???
Old Jun 13, 2007 | 10:50 AM
snake10556's Avatar
Default V8 swap....Which engines will work???
So i have a 91 RS cameroand i am wanting to swap that engine with a V8 350 but the problem is i cant find one, all i am finding isthe305. So i wanted to know which engines would be not terribly hard to put in to my car. I have been looking at Firebirds and Cameros of course but im not sure about trans ams and also what years can i go up to on those cars. I want to do this without having to go through to much work on the car itself.(besides the swap)
Also i herd that some 305 cam shafts were braking after like 80 thousand miles... is that true?
One more thing, for my car would it be hard to swap out the transmissions from a auto to a manual, my plan in this is to buy a car swap the engine, trans, and rearend.
Thanks in advance
Old Jun 13, 2007 | 04:19 PM
350rs's Avatar
March 2008 ROTM
Default RE: V8 swap....Which engines will work???
ANY chevy small block will bolt up to the current motor mounts, you could put as big of a small block in there as you want. i would stick with a 350, maybe a 383 depending on what your wanting out of the car.
havent heard that rumor about the cam, its doubtfull though.
as for the auto to manual swap... youll need all the linkage, clutch cylinders, new set of pedals. then a few more odds and ends that i cant remember.
Old Jun 13, 2007 | 06:37 PM
snake10556's Avatar
thanks for the answers, very appreciated.
Old Jun 13, 2007 | 06:57 PM
RS.Camaro.SS's Avatar
Look into getting just two speed powerstroke from an older model chevy/olds and have a tranny shop gear it up for you. It will make your life easier
9434V6
Sep 8, 2011 11:51 AM
87red
82-92 V6 Tech
23
Jun 28, 2009 10:47 AM
luvmysccamaro
Sep 14, 2008 12:39 PM
CCarRocks
82-92 V8 Tech
Nov 24, 2007 03:47 PM
ryder821
Apr 23, 2007 05:33 PM
