87 2.8 V6, which engines can i swap into it
Old Jun 8, 2009 | 02:32 PM
87red's Avatar
Default 87 2.8 V6, which engines can i swap into it
My engine just blew on the v6, are there any other engine sizes that I can drop right into it, or should I stick with the v6. Its a 87 2.8 multiport blah blah blah LT. any help is much appreciated.
Old Jun 8, 2009 | 03:01 PM
mighty mike's Avatar
to "drop right in" u have to stay v6. if ur ok with tools a v8 is no prob. to drop in just some minor work. but its well worth it.
Old Jun 8, 2009 | 04:05 PM
1990CamaroRS's Avatar
Fancy Sparkle
not nessicarily, i dropped in a GM Performance 350 into my RS. i blew it up and dropped the v6 back in and am now building the 350 into a 377. use factory mounts for a 305/350 and you won't have a problem. the transmission WON'T bolt up to a sbc though. different bell housing bolt patterns
Old Jun 8, 2009 | 04:46 PM
I think I saw a post on using a 3.4 short block with the 2.8 heads and intake. I think it will only add about 20 hp but it will give you a lot more usable torque at the low end.
Old Jun 8, 2009 | 07:02 PM
i did the same exact swap. same motor, same car. mines a 89 rs but with a six. hes goin from 6 to 8. u have to switch motor mounts. move brake lines, exhuast, etc
Old Jun 8, 2009 | 10:49 PM
Fancy Sparkle
if you're going to swap in a 3.4 block, just swap on some 3500 heads. 245bhp all motor.
and it was 3.4 with 3.1 heads. the 2.8's heads would limit the powerband to almost 4k rpm.
Old Jun 8, 2009 | 11:04 PM
RubberDucky's Avatar
Always cheaper on gas with a V6 lol.
Not to steal the thread, but 1990, how much would it cost to swap in a 3.4 with 3500 heads?
Old Jun 14, 2009 | 12:07 PM
Mpitera's Avatar
Wont he have to change the wireing and alot of other things to his car if he swaps out his 2.8 with a 350? I was planning on doing the same with my 89 RS but people keep telling me its not worth it because its to much work.
Old Jun 14, 2009 | 05:11 PM
if u got 350 tpi then yes its a pain in the hinney. if u go carbed like i did its really not hard at all.
Old Jun 16, 2009 | 04:55 PM
Mpitera's Avatar
If ya dont mind me asking.. how much did that run ya and where did you get it?
