Tranny making clicking sound when in reverse or low idle
Old Sep 6, 2007 | 01:24 AM
zerokool91's Avatar
Default Tranny making clicking sound when in reverse or low idle
When I put the car in reverse or all the way down to first gear. The transmission starts making a ticking sound. Almost like a small peice of metal pinging up against another metal surface. As well when I go down the road doing about 70 and if i floor it to pass someone. Its like the transmission cant make up its mind . It downshifts to 2nd and then back to drive and this will continuously happen until I release the accelerator. It's not good whatever it is. By the way its a 700R4 for a 91 camaro rs. What could this be ? I would like to catch the problem before it grows to something more catastrophic.
Thanks,
Chris
Old Sep 6, 2007 | 02:44 AM
MadMikeZ28's Avatar
Default RE: Tranny making clicking sound when in reverse or low idle
Maybe your pump is taking a ****. Low and 2nd have the highest pressures and if it keeps shifting when in 2nd it might be because there is not enough pressure. Or time for a fluid change and flush. Filter plugged??? Or if it is beyond a change its time for a rebuild
Old Sep 6, 2007 | 07:06 AM
zerokool91's Avatar
Yea I had a feeling if I change the filter and change the fluid in it that if it does not take care of it. That it was the pump going bad in it. I really hope not. My 91 is the only car I have to drive to college every day which is about 100+ miles a day.
TheDevilsBreed131
Jul 19, 2014 07:05 PM
NoSoupForYou83
Mar 20, 2013 02:54 PM
sngehl01
Mar 7, 2012 08:35 AM
mccoyj91
Oct 27, 2009 02:21 AM
snake10556
Sep 24, 2007 09:09 AM
