tach maxed out, please help
how do i take my dash off so i can get to my gauge cluster? do i take the bottom plastic off too?
note: u seem to be right about it working backwards camaro 69... when the car first starts it goes all the way to 0 and then its maxed out again.
Remove the lower dash cover and the plastic dash cluster trim piece. Then remove the mounting screws that holds the cluster to the dash. The cluster plugs directly into the dash when it gets set in place, no harness. Pull the cluster forward to unplug it. Then start tilting, rotating, turning, and twisting it to work it out past the right side of the steering column. It's tricky to get the right combination, but it will come out. Play with the tilt steering too to find the right position to gain clearance.
I had the same problem with the tach on my 92 Camaro. Tried the resistor fix but it didnt work. Finally found a tach board at the junkyard that worked for about a year.
I found a new replacement tach board. Only had it for about a week but it seemed to fix the problem! Hurray!!
NEW 1990-92 Chevy Camaro V8 Tachometer Circuit Board. DIRECT REPLACMENT!
Hey guys. We've been re manufacturing these tachometer circuit boards for years now. They are made her in the USA by trained technicians and come with a LIFETIME WARRANTY. We don't overcharge for these boards like the competition does. All components are sourced in the USA, no chinese junk on our boards. Please be cautious of others selling these circuit boards. We are the original re-manufacturer of these circuit
$39 SHIPPED to US
"This is a new, easy to install, direct replacement circuit board."
• Brand new tachometer circuit board for 90-92 Camaros.
• Only American made, high quality components are used.
• Direct replacement of the old circuit board that often fails or becomes inaccurate.
• Available for a V8 or V6. Includes fine adjustment ability if needed.
• Easy Installation, Just unplug your old tachometer chip and plug in the new circuit board. (Please indicate V6 or V8 engine when placing order).
• Lifetime Warranty, no hassle returns. No Questions Asked!
• Installation Instruction included. Easy to read with clear pictures.
• Fast & Free Shipping. Same day shipping if ordered before 11:00am.
https://www.ebay.com/itm/143159485015
Thanks! Greg
~ Cajun Tach shop
$39 SHIPPED to US
Thanks! Greg
~ Cajun Tach shop
Cajun Tach Shop was the original designer and producer of the new tachometer circuit boards for 82-92- Camaros. They are a veteran owned business that doesn't outsource parts and manufacturing. They offer a lifetime warranty and are much more reasonably priced! I called them on a Saturday and Greg walked me step by step through the installation process. I mean, what other company would do that! Very nice people and very professional.
https://www.cajuntachshop.com/produc...ircuit-board-1
