swapping Transmission in 89 RS
Old Mar 31, 2007 | 12:02 PM
jimmy2s83's Avatar
Default swapping Transmission in 89 RS
Hey,
I just bought a 89 RS with a 305 that purrs. Problem is that the Transmission(700r4) only has reverse. My intentions in the future is to have my 400sb in it paired to a th350 that is rated up to 500hp. The 400 was dynoed at 450hp. So right now I just want to put in the th350 and enjoy the car for the summer before I fully convert it. Any thing I should be aware of when doing this swap.
Jimmy
Old Apr 1, 2007 | 02:20 PM
Shmack2004's Avatar
Default RE: swapping Transmission in 89 RS
the drive shaft and rear end will need upgraded or that power will tear it to shreds...
Old Apr 1, 2007 | 02:54 PM
coprunr's Avatar
you will have to buy a kit to mount the torque arm because it mounts to the tailhousing on the 700R , you can get them through Summitracing for a decent price , the drivehshaft will have to be lengthened because the 350 turbo is 3" shorter than the 700R and as Shmack2004 stated the 7.625 rear diff. in the car won't live very long with 450hp and the torque of the 406 , usually 406's are torque monsters and you will break the rear diff. with little abuse
Old Apr 5, 2007 | 10:17 AM
jimmy2s83's Avatar
Thanks.
I remembered that I acutally have a TH350 that was in a 3rd gen and it had a special kit the guy had on it to fit. I will have to get the Driveshaft resized. I don't plan on putting the 406 in until the car is ready for it. The 305 still runs nice so I will enjoy it with that while I save up for a aftermarket rear to handle the additional power.
Thanks again guys.
Jimmy
NEVERLETITDIE
Jan 11, 2011 11:43 PM
97camaro89
Jul 16, 2010 10:13 PM
brad87
Jan 26, 2010 01:15 AM
ccamaro88
Jan 4, 2010 12:06 AM
wizard148
Jan 25, 2008 11:13 AM
