it stalls randomly and it idles too high
Old Jan 14, 2007 | 03:11 PM
pretty uniqe's Avatar
Default it stalls randomly and it idles too high
i drive down the road and it bogs. when i satrt it up it idles to high and when i put it in gear it stalls. and black smoke is coming from the exhaust. i don't know if this has to do with it, but it's hard to start when cold and i have to let it warm up before i put it in gear or it will stall on me. please help
Old Jan 14, 2007 | 03:20 PM
blackz87's Avatar
Default RE: it stalls randomly and it idles too high
Check for a vacuum leak.
Old Jan 14, 2007 | 03:26 PM
cubancamaro's Avatar
yea check for vacuum lines make sure they are all connected in the right places especially on your intake manifold and not sure if you got carb or tbi or what but make sure you lines are hook on there. Check your computer codes for possible defects to other sensors. Also change your fuel pump out it might be defective. I have a inline pump but if you still have your stock pump then I suggest you get a nice performance pump, its worth it. I had the same bogging problem you had. I couldnt go anywhere until the car warmed up and even then the car still bogged. I would press the gas and it like didnt want to go anywhere but if i held it long enough it would go. Unlike yours mine smoked white but not anymore. Anyway, thought that might help, if your situation is not the same then disregard. Also have you done a tune up on it and changed your IAC and TPS?that would help out too sometimes.
Old Jan 14, 2007 | 03:42 PM
ghotachevy's Avatar
map sensor maybe
anticypher0101
Mar 29, 2024 01:32 AM
shinwolf14
Jul 23, 2011 04:18 PM
Cobalt
Oct 18, 2009 09:24 PM
grimsleet
May 22, 2009 09:14 PM
jmdvegas
Aug 20, 2008 02:03 PM
