Running "Choppy"?
Old Dec 12, 2006 | 02:13 AM
Corr182's Avatar
Default Running "Choppy"?
Hey guys quick question, since ive had the car in march, ive never done a tune-up im thinking plugs and wires and while im at i might change the oil, when i drive the 91 z28 305 tpi, sometimes it idles really rough and has a loss of power, it only misfires,idles rough somedays, somedays it runs fine, any info? I was just going to do a tune up? thanks,
corr
Old Dec 12, 2006 | 04:21 AM
MadMikeZ28's Avatar
Default RE: Running "Choppy"?
Since you have not done it and most likely dont know when it was done last a tune would be a good place to start. Dont forget a fuel filter. And consider a tranny service also.
Old Dec 12, 2006 | 05:00 PM
Corr182's Avatar
I just got the tranny rebuilt not even a month ago.. if that means anything. to ya
Old Dec 12, 2006 | 06:50 PM
shnormo's Avatar
Also check your IAC Idle Air Control valve.
Old Dec 12, 2006 | 07:24 PM
FlufyTiger's Avatar
Then you should absolutely flush the tranny. The first 500 miles of a fresh rebuild are the worst thing the fluid can go through without far outliving the sevice life. And if anyone tells you you don't need it because the fluid looks good, never let them touch your car again. After that, get it flushed every 20k, no matter how it looks, and I would change the filter after the initial flush, too, if it were mine, then once every other flush. They only run about $15 around here, and come with a gasket.
Old Dec 13, 2006 | 01:08 AM
Corr182's Avatar
just take it somewhere and get it flushed?
Old Dec 13, 2006 | 02:12 AM
FlufyTiger's Avatar
Well, somewhere you trust, at least. Don't take it to Jiffy Lube.
roadstarjr
70-81 V8 Tech
Jul 21, 2015 05:25 PM
Jus22tin
Oct 4, 2011 10:17 AM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
kinglawrence
Jun 27, 2006 10:52 PM
