Removing ignition key cylinder help
Old Jul 13, 2007 | 02:55 AM
sewerrat's Avatar
Default Removing ignition key cylinder help
Can anyone tell me how to remove the ign. key cylinder from the steering column on my 88. I found a tilt steering from an 85 f-bird and it looks almost identical to my fixed style. I'd like to swap my original key cyl. into the tilt. My rep. manual doesn't show it. I remeber on my old chevy p/u I had toturn toacc. position then stick a thin metal somewhere on the side then continue to turn the cyl. counter clockwise but I'm not sure. Any replies greatly appreciated.
Old Jul 13, 2007 | 03:09 PM
MadMikeZ28's Avatar
Default RE: Removing ignition key cylinder help
http://elcaminocentral.com/article95.html
That shows how to tighten the loose tilt columns but part way is how to get the lock cylinder out. And it has pictures!
Old Jul 13, 2007 | 05:20 PM
scrounger's Avatar
Excellent link MadMike!
Old Jul 14, 2007 | 03:32 AM
sewerrat's Avatar
Thanks MadMike, Great link! Mine still feels pretty tight but I may as well go the whole nine yards since I'll be half way anyway. Might be a good Idea to check my horn wire and lube everything.
Old Jul 14, 2007 | 05:30 PM
MadMikeZ28's Avatar
If you go the whole way you will also need something to remove the pivot pins and a female torx socket to tighten the bolts that come loose.
auto
Sep 10, 2012 08:39 PM
Tony93Z28
Aug 27, 2012 01:16 PM
b_killa
Oct 27, 2006 03:13 AM
rwing7486
Jun 16, 2006 02:31 PM
thedvsone21
Jan 7, 2006 04:15 PM
