Rear end advice
#21
ah hell, go with it. www.spohn.net has an order for with all the options clearly shown and can answer any questions. i plan on ordering my rear through them and picking it up as im only an hour away. the rear i priced out is about $2800 to reuse factory disc brakes
#22
Also changing the rear axle assembly is a pretty straight forward job. But you should ask questions about the dr shaft and brake lines.
PS. These assemblies come unpainted so plan on painting it before installation. Por-15 would do the job.
#23
For sure i'll keep checking. It looks like I would need a new driveshaft, brake assemblies to convert to disk, new brake lines...etc. I'll need some local guy advice on what shops will do it and labor costs...Plus being how I am already a little low on vacuum @idle I may need a vacuum pump. It looks like over 3200 so far. Not cheap huh?
#25
After doing some more research...it appears after all is said and done it would be over the 4K mark to do the whole rear the way I would want it to be. I am still not opposed to doing it, but I may have to wait till I sell another race bike to feel comfortable spending that cash right now.
How bad would it be to use the same housing and put an eaton carrier with 3:xx and switch out the old axles and use hardened ones with a c-clip eliminator? Again, I'm opposed to the moser, or 9", but 4K is starting to get a little steep?
#26
Well go back to my first suggestion.
auto
10-01-2012 10:18 PM
camarokiller
21
11-02-2007 05:39 PM
