rear axle bent
Old 02-25-2010 | 10:01 PM
ozzy75701's Avatar
Default rear axle bent
My 92 Camaro RS was hit on the right rear and was pushed into a curb which bent the left axle. I found one for about $70 new that someone has that they do not need.It is from a 92 Camaro Z28 with disc brakes. My 92 RS has drum brakes. My question is,will the axle from the Z28 fit on my RS.Any help will be appreciated!!
Old 02-26-2010 | 03:12 PM
ScottD's Avatar
Any info? My advice is just get an entire rear end from a junkyard and be done with it. If you got hit hard enough to bend the axle, whats the rest of it look like inside.....????
Old 02-26-2010 | 05:51 PM
are u sure the rim is not the problem? it take s alot to bend and axle.
Old 02-26-2010 | 05:53 PM
I'd sure look at that housing very closely! If it bent the axle you've probably got a tweaked axle tube at the very least! I agree that I'd be looking for a complete assembly, not just the axle.
Old 02-27-2010 | 12:03 AM
ozzy75701's Avatar
I took it to a mechanic who pulled the wheel and ran it with wheel off while it was in air and the axle itself was wobling. I can still drive the car ,the wheel wobbles though. He said it should be fine to just replace the axle shaft, everthing else looks o.k.. will the Z28 axle work ? The dealer shows same part #, but I still want to be sure.Thanks for your help!!
Old 02-27-2010 | 12:13 AM
should fit. far as i know they are the same. keep your eyes open for a rearend of your choice with disk brakes so if it does start making noises u will be ready.
Old 02-27-2010 | 01:02 AM
1990-92 axles are 28 spline, earlier 3rd gens are 26 spline. Just make sure the new axle is what they say it is. You might think it's hard to tweak an axle, but not when you consider the thousands of pounds of side force you have when sliding sideways into a curb that doesn't move. The wheel and/or axle is the first to give before the tube gets damaged. Throw a straight edge on the axle tube for your own peace of mind, and compare left side to right.
Old 02-27-2010 | 09:12 PM
ScottD's Avatar
Im still saying your entire rear end is tweaked. Replacing the entire unit will be easier than replacing the axle.
Old 02-28-2010 | 08:56 AM
microkid's Avatar
March 2011 ROTM
Technical User
i also recomend replacing the entire axle, although checking the tube with a straight edge will let you know if its bent or not. do you know the length of the axle? i have a pair of 28 spline axles from my blazer that i could sell to you for $50 plus shipping.
maudyZ28
03-10-2010 08:22 AM
camaroguy992007
09-14-2008 05:55 PM
mayhem1988
82-92 V6 Tech
01-25-2008 07:25 AM
Danscamaro02SS
07-01-2007 10:26 PM
totaled108
02-26-2007 01:02 AM
Quick Reply: rear axle bent
