NOt cooling, no fans
Old Sep 14, 2005 | 01:31 AM
89Maro's Avatar
Default NOt cooling, no fans
I have an 89 5.7. The temp gauge is broken and tomnight the cooling resovour was boiling. ANy ideas why the fans are not going on? Can it be that the gauge is broken and not transmitting the need foer them to kick in? Can there be a broken fuse? Ironiclly, the hood light does not work either and the bulb is good.
Old Sep 14, 2005 | 03:36 PM
85Camarodude's Avatar
Default RE: NOt cooling, no fans
not sure about the gauge but as far as the fan not coming on, it could possibly be the 2 sensors that are supposed to kick it on have gone bad....im not sure where the sensors for an 89 5.7 are but mine are located 1: the intake thing where the filters are 2: it connects on the fan motor itself to somewhere near the passenger side near the battery to get power im assuming.......mine started messin up a while ago and i wiggled the 1st one i was talkin about and it started workin, i need to change mine i know for sure, i priced the sensor at advanced auto parts for like $10
hope that helps you out
Old Sep 14, 2005 | 06:34 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
my fan switch was under the passenger side head, only accessible from the bottom of the car, and the sending unit for the gaugue was under the drivers side head which you can get to from the top of the engine bay
Old Sep 26, 2005 | 03:39 AM
89Maro's Avatar
I eneded up changing the whole gauge. It works perfectly now and the fans work. Well one of them does. IT goes up and down and shuts off too :0 the only think is the nmbering in Degree's does not make logical sense. It says at cruise the car is 110* That does not make any logical sense to me.
Old Sep 26, 2005 | 05:14 PM
thirdgencamaro's Avatar
there are conectors that toutch each other in a relay by your fire wall and they go bad alot same happened on my 87. i would replace that and see what happens
Phalen123
Aug 13, 2010 12:15 AM
washtubman
82-92 V8 Tech
Mar 11, 2010 07:19 PM
Skippysnax
Jun 20, 2009 11:33 PM
lh883
Apr 28, 2007 08:12 PM
camaro girl
Mar 18, 2007 12:49 AM
