rims
Old Sep 26, 2005 | 11:57 PM
83Prostreeter's Avatar
Default rims
im buying a set of weld prostars 15 by 10. Im just curious about what backspacing should i use. The car is an 83 Z28 t-top with 406 small block with precision 88mm turbo
Old Sep 27, 2005 | 12:45 AM
thirdgencamaro's Avatar
Default RE: rims
Id go w/ a 1/2 or 3/4 in. spacing and use extended wheel studs. This way you have plenty of backspacing and enough bite on those studs so no probs will occur. Do you know the offset you are using?
luciora
Apr 12, 2010 08:18 PM
keith197431
May 29, 2009 07:34 PM
spisak
16
Nov 13, 2008 08:16 PM
94 z28
16
Feb 24, 2008 02:31 AM
90blackrs
Nov 25, 2007 11:20 AM
