LT1/LT4 Tech 1993-1997
Cooling fans?
Old Jun 9, 2009 | 03:49 PM
Skippysnax's Avatar
Cool Cooling fans?
My cooling fans in my 96 Lt1 m6 camaro have been acting up. At first they were turning on at weird times, and now they dont turn on at all. I hooked one of the fans up to a hotwire just to see if it worked. and it does. I didnt check the other one cause i figure its a wiring issue. I checked the harness that the fans run to and it is fine... i think. I dont really know how to check the relays though or if their is another wire harness i need to check. Any help would be great.
thanks
Old Jun 9, 2009 | 04:50 PM
heat sensor on the front driver side of the water pump tells the comperter what the temp is so it knows when to turn the fans on. relays usually dont go out together so one fan would be working and not the other, the relays are interchangable so if one is working and not the other u can change them and see if its the relay.
Old Jun 9, 2009 | 07:37 PM
Skippysnax's Avatar
ya i will check that sensor, but the only reason i noticed that my fans werent working, is that the temp was going through the roof at stop lights. so...
Old Jun 9, 2009 | 07:40 PM
the temp gage sensor is a different one than the engine temp sensor.
Old Jun 9, 2009 | 09:27 PM
torque_is_good's Avatar
just keep an eye on the temp and flick on the A/C which turns on the cooling fans. That will get you by as you figure out the cause.
Old Jun 9, 2009 | 09:31 PM
Stix80's Avatar
yeah i would also check the wiring from the sensor to the computer just to make sure the computer is getting the signal
Old Jun 20, 2009 | 11:33 PM
Skippysnax's Avatar
Replaced the sensor and they work fine now. thanks guys
Phalen123
Aug 13, 2010 12:15 AM
washtubman
82-92 V8 Tech
Mar 11, 2010 07:19 PM
usarmyrangrs
Jun 13, 2007 07:34 PM
lh883
Apr 28, 2007 08:12 PM
camaro girl
Mar 18, 2007 12:49 AM
