No idea what engine i have, how do i set timing?
Old Apr 23, 2011 | 09:14 PM
one92rs's Avatar
answer post #9/ which is mine on the timing tab. if you are using the wrong timing tab it will never be timed right.
1. did you remove a carb intake and swap another one?
2. or did you swap a fuel injection inake for a carb.
if #1 do what i said in post #9.
if it was carbed before then find tdc and restab the dizzy and retry it all again,.
Old Apr 24, 2011 | 02:06 AM
carguy68ssrs's Avatar
Did you get your car running??
Old Apr 24, 2011 | 12:51 PM
c4maro's Avatar
Well, i set it so the groove is about 2 inches from the right of the timing tab and the engine is now running smoother than it ever has and a noticeable power increase, i guess something was messed up when the rebuild was done because it runs like its on 5 clyinders when the groove is anywhere near the timing tab.
All is good now though, thanks for all the advice, really is appreciated.
Old Apr 24, 2011 | 02:26 PM
one92rs's Avatar
well if you want it to be precise then go to the link in post#9. that way you can get it dialed in perfectly.
Derch
70-81 V8 Tech
Jul 22, 2010 12:41 PM
ScottD
Mar 18, 2010 12:36 AM
berlinettalover
Jul 4, 2007 08:40 AM
Kev2002
May 18, 2007 09:06 AM
YouLost
Jul 28, 2006 06:26 PM
