NEED HELP 88 350 WITH A 83 CAMARO WORK WITH STOCK TRANS
I Got A 1983 Camaro Z28 Its A 5 Speed Stock 305ho Now I Bought A 1988 Chevy 350 For It I Went To Install It But Im Stuck With Mounting The Flywheel Because My Stock Tranny Holds A 26spline 11"dia Clutch And The Only Flywheel They Make For A 88 Bolt Pattern Is Made For A 10.4"dia Will My Tranny Work Wit A 10.4" Clutch Or Is There A Special Flywheel Or Do I Need A Newer Tranny
Pllleeeaaase Help Dying To Drive The Car....................
RE: NEED HELP 88 350 WITH A 83 CAMARO WORK WITH STOCK TRANS
Oh its possible to do, with mix matched parts. I ran into this problem doing a 350 swap on an 86 T/A once. Or, you can get a custom pressure plate made
