will 3.8 trans work in a 3.4
Old Feb 16, 2013 | 07:43 AM
Katzen's Avatar
Default will 3.8 trans work in a 3.4
i have a transmission for a 3.8 and a friend is wanting it but i dont know if it will work with his 3.4? can any of you help me? i dont want to give it to him and it not work
Old Feb 16, 2013 | 08:42 AM
nope, bolt pattern is different
Old Feb 16, 2013 | 01:19 PM
With SII 3800 GM when with the 60V bolt pattern. The bell housing bolt are the same, do you mean the converter? I am not sure of the diameter of the torque converter, I think the electronics will be differents because the 3.4 is OBD1 and the 3800 is OBD2
Old Feb 18, 2013 | 06:25 PM
Chaotic94's Avatar
September 2011 ROTM
Trans has the same part number. Use the 3.4 bell housing and 3.4 input shaft. Those are the only two parts of the trans that are different as far as I know.
Old Feb 19, 2013 | 08:06 AM
Are you say that no matter the year they are all the same? Because a 93 would not even be an E and completley different setup. I know on the LT1's 94-95's are old ***** because of the PCM shifting harness.
Old Feb 19, 2013 | 08:33 AM
Chaotic is reefering to a manual trans. Katzen never said if he was talking about an auto or manny tranny.
Old Feb 19, 2013 | 10:53 AM
Ha,,, didn't even notice, I always assume auto unless they say stick.
Old Feb 20, 2013 | 10:04 AM
Katzen's Avatar
oh sorry, yeah it is auto
Old Feb 20, 2013 | 10:53 AM
So the short answer is no it is not plug and play.
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
80ZJoe
Mar 30, 2011 12:05 PM
camaroz803
Jul 28, 2010 10:59 PM
nvr2fast
Aug 21, 2006 07:29 PM
