My starter done BLOWED UP!
Old Jul 7, 2007 | 09:50 PM
ScottD's Avatar
Default RE: My starter done BLOWED UP!
Wow, rump rangers. Thats original. Hey new guy (michaelberryhill17) , 5th grade called, they want their insults back......
Old Jul 8, 2007 | 12:20 AM
74454bb's Avatar
May 2007 ROTM
Yeah this guy is a moron.
Old Jul 8, 2007 | 01:22 AM
MadMikeZ28's Avatar
Look at his post. All he does is post his imature comments. Can a Mod get rid of him, her,it???
Old Jul 8, 2007 | 01:25 AM
74454bb's Avatar
May 2007 ROTM
Yeah I seen...2 verry stupid questions and 6 half baked insults....like he'll get help from us now
Old Jul 8, 2007 | 08:07 PM
ORIGINAL: ScottD
Well I got under her again tonight and chased the threads, at least that went well. These aftermarket starter bolts took a but of work to hold her tight, but I got it all hooked up again. (Had to grind some threads down so they wouldnt bottom out in the blind holes) I then measured the pinion to flywheel clearance and it seems that Ive got about .065-. 075. The manual (aftermarket starter)says anything over .060 is too much. I guess with the old starter bolts and that much clearance, it might have been causing the problem. Now, here is my question......how do I fix it? The manual says to shim one side, but thats what I did last night just prior to her blowing up! I was wondering if I took the starter to a machine shop and told them to take .025 off the top (portion that meets the block) of the starter, would that work? Im out of options here........
I know you took a look at the flywheel, but you may want to look at it again and check for some bent or missing teeth that prevent the starter from engaging properly.
RJ350
Sep 21, 2012 07:26 PM
iLL95
Oct 17, 2011 02:51 AM
VanHalen
Jan 6, 2010 09:02 PM
camarodrifter
Dec 29, 2006 08:08 PM
94Z28interceptor
Nov 14, 2006 08:09 PM
